Differential Forgery Attack against LAC - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Gaëtan Leurent
  • Fonction : Auteur
  • PersonId : 951331
LAC is one of the candidates to the CAESAR competition. In this note we present a differential forgery attack on LAC. We show that some differentials have a probability higher than 2^-64, using a collection of characteristics in order to evaluate a lower bound on the probability of a differential. This allows a forgery attack on the full LAC. This work illustrates the difference between the probability of differentials and characteristics.
lac.pdf (154.09 Ko) Télécharger le fichier
hal-01017048 , version 1 (01-07-2014)
hal-01017048 , version 2 (14-12-2015)
  • HAL Id : hal-01017048 , version 1
Gaëtan Leurent. Differential Forgery Attack against LAC. 2014. ⟨hal-01017048v1⟩
319 Consultations
423 Téléchargements
