Blind suppression of nonstationary diffuse noise based on spatial covariance matrix decomposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Signal Processing Systems Année : 2015
We propose methods for blind suppression of nonstationary diffuse noise based on decomposition of the observed spatial covariance matrix into signal and noise parts. In modeling noise to regularize the ill-posed decomposition problem, we exploit spatial invariance (isotropy) instead of temporal invariance (stationarity). The isotropy assumption is that the spatial cross-spectrum of noise is dependent on the distance between microphones and independent of the direction between them. We propose methods for spatial covariance matrix decomposition based on least squares and maximum likelihood estimation. The methods are validated on real-world recordings.
ito_JSPS14.pdf (572.99 Ko) Télécharger le fichier
hal-01020255 , version 1 (08-07-2014)
Nobutaka Ito, Emmanuel Vincent, Tomohiro Nakatani, Nobutaka Ono, Shoko Araki, et al.. Blind suppression of nonstationary diffuse noise based on spatial covariance matrix decomposition. Journal of Signal Processing Systems, 2015, 79 (2), pp.145-157. ⟨10.1007/s11265-014-0922-z⟩. ⟨hal-01020255⟩
266 Consultations
485 Téléchargements
