Data Normalization for Foundation SHM of an Offshore Wind Turbine : A Real-Life Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this contribution the first results in the development of a SHM approach for the foundations of an offshore wind turbine will be presented. Key problems are the operational and environmental variability of the resonance frequencies of the turbine. This paper suggests a (non-)linear regression model to perform data normalization. Real-life data obtained from an offshore turbine on a monopile is used to validate the used model and to demonstrate the performance of the presented approach.
0163.pdf (1.72 Mo) Télécharger le fichier
hal-01020449 , version 1 (08-07-2014)
  • HAL Id : hal-01020449 , version 1
Wout Weijtjens, Tim Verbelen, Gert de Sitter, Christof Devriendt. Data Normalization for Foundation SHM of an Offshore Wind Turbine : A Real-Life Case Study. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01020449⟩
271 Consultations
337 Téléchargements
