Identifying change patterns of concept attributes in ontology evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ontology versions are periodically released to ensure their usefulness and reliability over time. This potentially impacts dependent artefacts such as mappings and annotations. To deal with this issue re- quires to nely characterize ontology entities' changes between ontology versions. This article proposes to identify change patterns at attribute values when an ontology evolves, to track textual statements describing concepts. We empirically evaluate our approach by using biomedical on- tologies, for which new ontology versions are frequently released. Our achieved results suggest the feasibility of the proposed techniques.
ESWC-2014.pdf (254.02 Ko) Télécharger le fichier
hal-01020921 , version 1 (08-07-2014)
  • HAL Id : hal-01020921 , version 1
Duy Dinh, Julio Cesar dos Reis, Cédric Pruski, Marcos da Silveira, Chantal Reynaud-Delaître. Identifying change patterns of concept attributes in ontology evolution. 11th Extended Semantic Web Conference (ESWC) 2014, May 2014, Anissaras/Heronissou, Greece. ⟨hal-01020921⟩
89 Consultations
248 Téléchargements
