Early-Age Concrete Strength Estimation Technique using Embedded Piezoelectric self-sensing impedance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently, demands for the construction of Nuclear Power Plants (NPP) using high strength concrete (HSC) has been increased. However, HSC might be susceptible to brittle fracture if the curing process is inadequate. To prevent unexpected collapse during and after the construction of HSC structures, it is essential to confirm the strength development of HSC during the curing process. However, several traditional strength-measuring methods are not effective and practical. In this study, a novel method to estimate the strength development of HSC based on electromechanical impedance (EMI) measurements using an embedded piezoelectric sensor is proposed. The EMI of NPP concrete specimen was tracked to monitor the strength development. In addition, cross-correlation coefficient was applied in sequence to examine the trend of the impedance variations more quantitatively. The results confirmed that the proposed technique can be applied successfully monitoring of the strength development during the curing process of HSC structures.
0451.pdf (397.29 Ko) Télécharger le fichier
hal-01021243 , version 1 (09-07-2014)
  • HAL Id : hal-01021243 , version 1
Junkyeong Kim, Ju-Won Kim, Seunghee Park. Early-Age Concrete Strength Estimation Technique using Embedded Piezoelectric self-sensing impedance. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01021243⟩
181 Consultations
293 Téléchargements
