Principal Component Analysis for Fault Detection and Structure Health Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The aim of this paper is to propose an algorithm for detecting faults such as cracks in an underground structure to ensure its health monitoring. The proposed approach is based on the PCA algorithm. Once PCA components are computed, we can see easily the impact of a crack on their norms. The impact represents a good indication to detect abrupt change.
0135.pdf (552.78 Ko) Télécharger le fichier
hal-01022020 , version 1 (10-07-2014)
  • HAL Id : hal-01022020 , version 1
Nicolas Stoffels, Vincent Sircoulomb, Guillaume Hermand, Ghaleb Hoblos. Principal Component Analysis for Fault Detection and Structure Health Monitoring. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022020⟩
243 Consultations
832 Téléchargements
