Gearbox Condition Monitoring under Variable Operational Conditions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The gearbox vibration spectrum is complicated and overloaded with artefacts, making it difficult for the eye to register a change due to a fault. In order to overcome this difficulty this paper presents a gearbox condition indicator, which can be trended. The gearbox condition indicator is based on the summation of the sideband levels around the first three harmonics of the gear mesh frequency. The sensitivity of the proposed gearbox condition indicator to damage is investigated using seeded improper backlash under a range of operational conditions.
0304.pdf (498.55 Ko) Télécharger le fichier
hal-01022050 , version 1 (10-07-2014)
  • HAL Id : hal-01022050 , version 1
Daniela Toshkova, Nicholas Lieven, Peter Morrish, Branislav Titurus, Will Moore, et al.. Gearbox Condition Monitoring under Variable Operational Conditions. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022050⟩
261 Consultations
1158 Téléchargements
