On the Damage Diagnosis Based on Structural Analysis Data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
One of the major challenges of Structural Health Monitoring (SHM) is to handle the enormous amount of data during the monitoring action. This is due to the fact that common SHM approaches monitor the entire structure on all kind of damages in order to obtain all eventualities of damage. The idea of this contribution is to use the information of the partÕs sizing in order to identify so called hot spots, i.e. possible damage locations and the corresponding kind of damage like cracks or delaminations. With this information a SmartSHM system is set up, which monitors only the hot spots on the most likely failure. To cover uncertainties and accidental damages an additional monitoring of a global parameter has to be set up. This approach is shown based on an example of a four point bending test with a rectangular cross-section.
0345.pdf (223.63 Ko) Télécharger le fichier
hal-01022996 , version 1 (11-07-2014)
hal-01022996 , version 2 (15-07-2014)
  • HAL Id : hal-01022996 , version 1
Kai-Uwe Schröder, Andreas Preisler, Christoph Viechtbauer, Martin Schagerl. On the Damage Diagnosis Based on Structural Analysis Data. EWSHM - 7th European Workshop on Structural Health Monitoring, IFFSTTAR, Inria, Université de Nantes, Jul 2014, Nantes, France. ⟨hal-01022996v1⟩
524 Consultations
277 Téléchargements
