Elliptic PDEs with distributional drift and backward SDEs driven by a càdlàg martingale with random terminal time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Stochastics and Dynamics Année : 2017
We introduce a generalized notion of semilinear elliptic partial differential equations where the corresponding second order partial differential operator $L$ has a generalized drift. We investigate existence and uniqueness of generalized solutions of class $C^1$. The generator $L$ is associated with a Markov process $X$ which is the solution of a stochastic differential equation with distributional drift. If the semilinear PDE admits boundary conditions, its solution is naturally associated with a backward stochastic differential equation (BSDE) with random terminal time, where the forward process is $X$. Since $X$ is a weak solution of the forward SDE, the BSDE appears naturally to be driven by a martingale. In the paper we also discuss the uniqueness of a BSDE with random terminal time when the driving process is a general càdlàg martingale.
StrongSolution2015June2SubmittedRevision.pdf (247.05 Ko) Télécharger le fichier
hal-01023176 , version 1 (11-07-2014)
hal-01023176 , version 2 (02-06-2015)
Francesco Russo, Lukas Wurzer. Elliptic PDEs with distributional drift and backward SDEs driven by a càdlàg martingale with random terminal time. Stochastics and Dynamics, 2017, 17, pp.1750030. ⟨10.1142/S0219493717500307⟩. ⟨hal-01023176v2⟩
245 Consultations
368 Téléchargements
