Elliptic PDEs with distributional drift and backward SDEs driven by a càdlàg martingale with random terminal time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
We introduce a generalized notion of semilinear elliptic partial differential equations where the corresponding second order partial differential operator $L$ has a generalized drift. We investigate existence and uniqueness of generalized solutions of class $C^1$. The generator $L$ is associated with a Markov process $X$ which is the solution of a stochastic differential equation with distributional drift. If the semilinear PDE admits boundary conditions, its solution is naturally associated with a backward stochastic differential equation (BSDE) with random terminal time, where the forward process is $X$. Since $X$ is a weak solution of the forward SDE, the BSDE appears naturally to be driven by a martingale. In the paper we also discuss the uniqueness of a BSDE with random terminal time when the driving process is a general càdlàg martingale.
StrongSolution20140711Final.pdf (232.99 Ko) Télécharger le fichier
hal-01023176 , version 1 (11-07-2014)
hal-01023176 , version 2 (02-06-2015)
Francesco Russo, Lukas Wurzer. Elliptic PDEs with distributional drift and backward SDEs driven by a càdlàg martingale with random terminal time. 2014. ⟨hal-01023176v1⟩
Collections
PARISTECH
246 Consultations
368 Téléchargements
