Quick reachability and proper extension for problems with unbounded controls
For a CONTROL SYSTEM of the form _ x = f (x; u; v) + Σm =1 g (x)u_ ; on [0;T]; (x; u)(0) = ( x; u); with x : [0;T] ! IRn; u : [0;T] ! U IRm; v : [0;T] ! V IRl ; we rely on the notion of LIMIT SOLUTION, and we investigate whether minimum problems with L1controls are PROPER EXTENSIONS of regular problems with more regular controls (AC or BV). Motivation: optimality conditions, numerical methods, etc.
Optimisation et contrôle [math.OC]
