Sufficient Conditions for Strong Local Optimality with Applications to Biomedical Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2014
We consider optimal control problems over a fixed interval for multi-input bilinear dynamical systems with both $L_1$ and $L_2$-type objectives in the presence of control constraints. Problems of this type arise as mathematical models for cancer chemotherapy over an a priori specified fixed therapy horizon. The extremals resulting from an application of the Pontryagin maximum principle are analyzed. Conditions are given that allow to embed extremals into a field of broken extremals leading to easily verifiable sufficient conditions for strong local optimality. In the case of an $L_1$-type objective, flows of extremal bang-bang trajectories arise for which a simple algorithmic procedure to verify local optimality will be formulated. In the case of an $L_2$-type objective, sufficient conditions for strong local optimality that are based on the existence of a bounded solution to a matrix Riccati differential equation will be formulated. The theory is illustrated with a $3$-compartment model for multi-drug cancer chemotherapy with cytotoxic and cytostatic agents.
UrszulaLedzewicz-NETCO2014.pdf (6.06 Mo) Télécharger le fichier
hal-01024597 , version 1 (16-07-2014)
  • HAL Id : hal-01024597 , version 1
Urszula Ledzewicz. Sufficient Conditions for Strong Local Optimality with Applications to Biomedical Problems. NETCO 2014 - New Trends in Optimal Control, Jun 2014, Tours, France. ⟨hal-01024597⟩
98 Consultations
42 Téléchargements
