Complexity in control-affine systems
We will consider affine-control systems, i.e., systems in the form _ q(t) = f0(q(t)) + Xm i=1 ui (t)fi (q(t)) Here, the point q belongs to a smooth manifold M the fi 's are smooth vector fields on M u 2 L1([0;T];Rm) This type of system appears in many applications Mechanical systems Quantum control Microswimmers (Tucsnak, Alouges) Neuro-geometry of vision (Mumfor, Petitot)
Optimisation et contrôle [math.OC]
