An Approach to Derive Usage Models Variants for Model-based Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ralf Bogusch
  • Fonction : Auteur
  • PersonId : 957176
Mathieu Acher
Benoit Baudry
  • Fonction : Auteur
  • PersonId : 838700
Testing techniques in industry are not yet adapted for product line engineering (PLE). In particular, Model-based Testing (MBT), a technique that allows to automatically generate test cases from requirements, lacks support for managing variability (differences) among a set of related product. In this paper, we present an approach to equip usage models, a widely used formalism in MBT, with variability capabilities. Formal correspondences are established between a variability model, a set of functional requirements, and a usage model. An algorithm then exploits the traceability links to automatically derive a usage model variant from a desired set of selected features. The approach is integrated into the professional MBT tool MaTeLo and is currently used in industry.
MasterTex.pdf (816.66 Ko) Télécharger le fichier
hal-01025124 , version 1 (17-07-2014)
hal-01025124 , version 2 (29-11-2016)
  • HAL Id : hal-01025124 , version 1
Hamza Samih, Hélène Le Guen, Ralf Bogusch, Mathieu Acher, Benoit Baudry. An Approach to Derive Usage Models Variants for Model-based Testing. The 26th IFIP International Conference on Testing Software and Systems (2014), Sep 2014, Madrid, Spain. ⟨hal-01025124v1⟩
Collections
IRISA-D4 INRIA2
1345 Consultations
416 Téléchargements
