A Principled Way of Assessing Visualization Literacy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2014
We describe a method for assessing the visualization literacy (VL) of a user. Assessing how well people understand visualizations has great value for research (e. g., to avoid confounds), for design (e. g., to best determine the capabilities of an audience), for teaching (e. g., to assess the level of new students), and for recruiting (e. g., to assess the level of interviewees). This paper proposes a method for assessing VL based on Item Response Theory. It describes the design and evaluation of two VL tests for line graphs, and presents the extension of the method to bar charts and scatterplots. Finally, it discusses the reimplementation of these tests for fast, effective, and scalable web-based use.
vLiteracy.pdf (1.25 Mo) Télécharger le fichier
pres_VIS_Literacy.pdf (1.38 Mo) Télécharger le fichier
Format : Présentation
hal-01027582 , version 1 (26-03-2015)
Jeremy Boy, Ronald A. Rensink, Enrico Bertini, Jean-Daniel Fekete. A Principled Way of Assessing Visualization Literacy. IEEE Transactions on Visualization and Computer Graphics, 2014, 20 (12), pp.10. ⟨10.1109/TVCG.2014.2346984⟩. ⟨hal-01027582⟩
474 Consultations
4297 Téléchargements
