Parameterized Communicating Automata: Complementation and Model Checking - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We study the language-theoretical aspects of parameterized communicating automata (PCAs), in which processes communicate via rendez-vous. A given PCA can be run on any topology of bounded degree such as pipelines, rings, ranked trees, bus topologies, and grids. We show that, under a context bound, which restricts the local behavior of each process, PCAs are effectively complementable. Complementability is considered a key aspect of robust automata models and can, in particular, be exploited for verification. In this paper, we use it to obtain a characterization of context-bounded PCAs in terms of monadic second-order (MSO) logic. As the emptiness problem for context-bounded PCAs is decidable for the classes of pipelines, rings, and trees, their model-checking problem wrt. MSO properties also becomes decidable. While previous work on model checking parameterized systems typically uses temporal logics without next operator, our MSO logic allows one to express several natural next modalities.
complementation.pdf (1.09 Mo) Télécharger le fichier
hal-01030765 , version 1 (22-07-2014)
  • HAL Id : hal-01030765 , version 1
Benedikt Bollig, Paul Gastin, Akshay Kumar. Parameterized Communicating Automata: Complementation and Model Checking. 34th Conference on Foundations of Software Technology and Theoretical Computer Science (FSTTCS'14), Dec 2014, New Delhi, India. ⟨hal-01030765⟩
496 Consultations
172 Téléchargements
