Planning Human-Computer Improvisation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Improvisation intrinsically carries a dialectic between spontaneity/reactivity and long-term planning/organization. This paper transposes this dialectic to interactive human-computer improvisation where the computer has to interleave various generative processes. They require different levels of prior knowledge, and follow a coarser improvisation plan driven by real-time interactions with the musicians. We propose a time-aware extensible architecture allowing the temporal coordination of different improvisation strategies. It integrates various generative strategies capitalizing on the sys- tem Improtek into the high-level structure provided by the language associated to the score follower Antescofo. The resulting framework manages the musical events, the trig- gering of generative processes at different time scales and the declarative specification of improvisation plans driven by the occurrence of complex events.
ArticleICMC2014.pdf (531.12 Ko) Télécharger le fichier
hal-01053834 , version 1 (11-08-2014)
hal-01053834 , version 2 (13-08-2014)
  • HAL Id : hal-01053834 , version 1
Jérôme Nika, José Echeveste, Marc Chemillier, Jean-Louis Giavitto. Planning Human-Computer Improvisation. International Computer Music Conference, Sep 2014, Athens, Greece. pp.330. ⟨hal-01053834v1⟩
488 Consultations
334 Téléchargements
