Delegation in Predicate Encryption Supporting Disjunctive Queries
Predicate encryption has an advantage over traditional public-key or identity-based encryption, since predicate encryption systems provide more flexible control over access to encrypted data. We focus on delegation capabilities in predicate systems. More specifically, we investigate delegatable encryption systems supporting disjunctive predicate evaluations. We present formal security definitions of delegatable predicate encryption and provide the first delegatable predicate encryption scheme which supports disjunctive predicate evaluations in the public-key setting. We analyze the security of the proposed system and give a security proof.
Bibliothèque électronique [cs.DL]
20-Paper-175-Delegation_in_Predicate_Encryption_Supporting_Disjunctive_Queries-Dongdong_Sun.pdf (122.38 Ko)
Télécharger le fichier
