Research Methodologies in Information Security Research: The Road Ahead - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This panel discussion will examine the methodological traditions currently existing amongst the fraternity of information security researchers. Information security researchers commonly engage in research activities ranging from the highly technical, to the "softer" human orientated. As such, researchers engaged in the field of information security could potentially make use of research philosophies, paradigms, and methodologies ranging from the quantitative/positivist to the interpretive/qualitative. This panel discussion will examine current trends in the selection and use of research methodologies amongst researchers from the information security fraternity and will attempt to address issues relating to such choices. Finally the possible impact of methodological traditions from the human and social sciences on future information security research activities will be discussed.
18-PanelDiscussion-Research_Methodologies_in_Information_Security_Research_The_road_ahead-van_Niekerk_Johan.pdf (54.54 Ko) Télécharger le fichier
hal-01054516 , version 1 (07-08-2014)
Paternité
Johan F. Niekerk, Rossouw Solms. Research Methodologies in Information Security Research: The Road Ahead. 25th IFIP TC 11 International Information Security Conference (SEC) / Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.215-216, ⟨10.1007/978-3-642-15257-3_19⟩. ⟨hal-01054516⟩
153 Consultations
137 Téléchargements
