Representing Visual Appearance by Video Brownian Covariance Descriptor for Human Action Recognition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses a problem of recognizing human actions in video sequences. Recent studies have shown that methods which use bag-of-features and space-time features achieve high recognition accuracy. Such methods extract both appearance-based and motion-based features. This paper focuses only on appearance features. We proposeto model relationships between different pixel-level appearance features such as intensity and gradient using Brownian covariance, which is a natural extension of classical covariance measure. While classical covariance can model only linear relationships, Brownian covariance models all kinds of possible relationships. We propose a method to compute Brownian covariance on space-time volume of a video sequence. We show that proposed Video Brownian Covariance (VBC) descriptor carries complementary information to the Histogram of Oriented Gradients (HOG) descriptor. The fusion of these two descriptors gives a significant improvement in performance on three challenging action recognition datasets.
Bilinski-VideoBrownianCovariance-AVSS2014.pdf (380.29 Ko) Télécharger le fichier
hal-01054943 , version 1 (11-08-2014)
hal-01054943 , version 2 (06-11-2014)
  • HAL Id : hal-01054943 , version 2
Piotr Bilinski, Michal Koperski, Slawomir Bak, François Bremond. Representing Visual Appearance by Video Brownian Covariance Descriptor for Human Action Recognition. AVSS - 11th IEEE International Conference on Advanced Video and Signal-Based Surveillance, IEEE, Aug 2014, Seoul, South Korea. ⟨hal-01054943v2⟩
Collections
INRIA INRIA2
194 Consultations
311 Téléchargements
