An Efficient Data Indexing Approach on Hadoop Using Java Persistence API - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Data indexing is common in data mining when working with high-dimensional, large-scale data sets. Hadoop, a cloud computing project using the MapReduce framework in Java, has become of significant interest in distributed data mining. To resolve problems of globalization, random-write and duration in Hadoop, a data indexing approach on Hadoop using the Java Persistence API (JPA) is elaborated in the implementation of a KD-tree algorithm on Hadoop. An improved intersection algorithm for distributed data indexing on Hadoop is proposed, it performs O(M+logN), and is suitable for occasions of multiple intersections. We compare the data indexing algorithm on open dataset and synthetic dataset in a modest cloud environment. The results show the algorithms are feasible in large-scale data mining.
An_Efficient_Data_Indexing_Approach_on_Hadoop_using_Java_Persistence_API.pdf (484.95 Ko) Télécharger le fichier
Dates and versions
hal-01055056 , version 1 (11-08-2014)
Attribution
Identifiers
Cite
Yang Lai, Shi Zhongzhi. An Efficient Data Indexing Approach on Hadoop Using Java Persistence API. 6th IFIP TC 12 International Conference on Intelligent Information Processing (IIP), Oct 2010, Manchester, United Kingdom. pp.213-224, ⟨10.1007/978-3-642-16327-2_27⟩. ⟨hal-01055056⟩
277 View
405 Download
Share
