Specification and Testing of E-Commerce Agents Described by Using UIOLTSs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we expand our work in our specification formalism UIOLTSs. We present three implementation relations and provide alternative characterizations of these relations in terms of the tests that the implementation under test successfully passes. In addition, we present the main ideas to obtain an algorithm to derive complete test suites from specifications.
61170077.pdf (126.3 Ko) Télécharger le fichier
hal-01055144 , version 1 (11-08-2014)
Paternité
Juan José Pardo, Manuel Núñez, M. Carmen Ruiz. Specification and Testing of E-Commerce Agents Described by Using UIOLTSs. Joint 12th IFIP WG 6.1 International Conference on Formal Methods for Open Object-Based Distributed Systems (FMOODS) / 30th IFIP WG 6.1 International Conference on Formal Techniques for Networked and Distributed Systems (FORTE), Jun 2010, Amsterdam, Netherlands. pp.78-86, ⟨10.1007/978-3-642-13464-7_7⟩. ⟨hal-01055144⟩
74 Consultations
143 Téléchargements
