Test Data Generation for Programs with Quantified First-Order Logic Specifications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a novel algorithm for test data generation that is based on techniques used in formal software verification. Prominent examples of such formal techniques are symbolic execution, theorem proving, satisfiability solving, and usage of specifications and program annotations such as loop invariants. These techniques are suitable for testing of small programs, such as, e.g., implementations of algorithms, that have to be tested extremely well. In such scenarios test data is generated from test data constraints which are first-order logic formulas. These constraints are constructed from path conditions, specifications, and program annotation describing program paths that are hard to be tested randomly. A challenge is, however, to solve quantified formulas. The presented algorithm is capable of solving quantified formulas that state-of-the-art satisfiability modulo theory (SMT) solvers cannot solve. The algorithm is integrated in the formal verification and test generation tool KeY .
paper_TML2L.pdf (251.69 Ko) Télécharger le fichier
hal-01055252 , version 1 (12-08-2014)
Paternité
Christoph D. Gladisch. Test Data Generation for Programs with Quantified First-Order Logic Specifications. 22nd IFIP WG 6.1 International Conference on Testing Software and Systems (ICTSS), Nov 2010, Natal, Brazil. pp.158-173, ⟨10.1007/978-3-642-16573-3_12⟩. ⟨hal-01055252⟩
58 Consultations
72 Téléchargements
