A Model-Driven Software Development Approach Using OMG DDS for Wireless Sensor Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The development of embedded systems challenges software engineers with timely delivery of optimised code that is both safe and resource-aware. Within this context, we focus on distributed systems with small, specialised node hardware, specifically, wireless sensor network (WSN) systems. Model-driven software development (MDSD) promises to reduce errors and efforts needed for complex software projects by automated code generation from abstract software models. We present an approach for MDSD based on the data-centric OMG middleware standard DDS. In this paper, we argue that the combination of DDS features and MDSD can successfully be applied to WSN systems, and we present the design of an appropriate approach, describing an architecture, metamodels and the design workflow. Finally, we present a prototypical implementation of our approach using a WSN-enabled DDS implementation and a set of modelling and transformation tools from the Eclipse Modeling Framework.
paper.pdf (360.25 Ko) Télécharger le fichier
hal-01055394 , version 1 (12-08-2014)
Paternité
Kai Beckmann, Marcus Thoss. A Model-Driven Software Development Approach Using OMG DDS for Wireless Sensor Networks. 8th IFIP WG 10.2 International Workshop on Software Technologies for Embedded and Ubiquitous Systems (SEUS), Oct 2010, Waidhofen/Ybbs, Austria. pp.95-106, ⟨10.1007/978-3-642-16256-5_11⟩. ⟨hal-01055394⟩
114 Consultations
294 Téléchargements
