Wireless Sensor Networks Applied on Environmental Monitoring in Fowl Farm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aiming at the real time monitoring requirement of poultry farms on the environment, a online monitoring system is proposed for poultry farms on the environment based on ZigBee, its application of ZigBee wireless networks and sensor technology. supply a network structure of monitoring system, monitoring system node controller of data acquisition, data transmission and control node, which is TI's CC2430 based on ZigBee technology. CO2 sensors use TGS4161, temperature and humidity sensors use SHT75 to detect environmental parameters. designed circuit diagram of parameter testing node and system master control node, CC2430 as a data processing chip. through the analysis of data transmission of system, simplifying the ZigBee protocol stack, designed data transmission protocols and communication formats of the system. given program flow chart of sensors nodes and main node. practical application shows that the performance ratio cable monitoring system is better, Especially in real-time systems and anti-jamming, it so superior on the current forms of environmental monitoring SCM cable system which cost lower than the SCM cable control system about 30%.Successfully achieved the Monitoring of fowlery's CO2 concentration, temperature, humidity and other environmental parameters for large-scale poultry farming, and to provide a new monitoring environment technologie.
1302--Fangwu_Dong.pdf (150.14 Ko) Télécharger le fichier
hal-01055409 , version 1 (12-08-2014)
Paternité
Fangwu Dong, Naiqing Zhang. Wireless Sensor Networks Applied on Environmental Monitoring in Fowl Farm. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.479-486, ⟨10.1007/978-3-642-12220-0_70⟩. ⟨hal-01055409⟩
117 Consultations
716 Téléchargements
