Digital Modeling and Testing Research on Digging Mechanism of Deep Rootstalk Crops - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The digital model of the laboratory bench parts of digging deep rootstalk crops were established through adopting the parametric model technology based on feature. The virtual assembly of the laboratory bench of digging deep rootstalk crops was done and the digital model of the laboratory bench parts of digging deep rootstalk crops was gained. The vibrospade, which is the key part of the laboratory bench of digging deep rootstalk crops was simulated and the movement parametric curves of spear on the vibrospade were obtained. The results show that the spear was accorded with design requirements. It is propitious to the deep rootstalk.
1026--Chunhua_Yang.pdf (349.32 Ko) Télécharger le fichier
hal-01055423 , version 1 (12-08-2014)
Paternité
Chuanhua Yang, Ma Xu, Zhoufei Wang, Wenwu Yang, Xinglong Liao. Digital Modeling and Testing Research on Digging Mechanism of Deep Rootstalk Crops. Third IFIP TC 12 International Conference on Computer and Computing Technologies in Agriculture III (CCTA), Oct 2009, Beijing, China. pp.382-388, ⟨10.1007/978-3-642-12220-0_56⟩. ⟨hal-01055423⟩
146 Consultations
137 Téléchargements
