A Composite Task Meta-Model as a Reference Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we develop a comprehensive composite meta-model from Task Analysis models called the Reference Task Meta-model (ReTaMeta model) for the purpose of comparing numerous Agent-Oriented meta-models. The reference model needed to be derived from a field independent of the Agent-oriented paradigm, yet based on Psychology. To arrive at the ReTaMeta model we first extracted the meta-models from several well-known cognitive task models including GOMS, GOMSL, TKS, GTA and also the CTT and Diane+H Task Modeling notations for fine grain task detail, and then combined their respective concepts in a complementary and comprehensive way.
2_3_Goschnick.pdf (324.75 Ko) Télécharger le fichier
hal-01055463 , version 1 (13-08-2014)
Paternité
Steve Goschnick, Liz Sonenberg, Sandrine Balbo. A Composite Task Meta-Model as a Reference Model. Second IFIP TC 13 Symposium on Human-Computer Interaction (HCIS)/ Held as Part of World Computer Congress (WCC), Sep 2010, Brisbane, Australia. pp.26-38, ⟨10.1007/978-3-642-15231-3_4⟩. ⟨hal-01055463⟩
135 Consultations
136 Téléchargements
