Eye Contact Communication System between Mobile Robots Using Invisible Code Display - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The authors have been developing the mobile robots which can cooperation between robots. The robots should communicate with each other in order to cooperate together. Therefore, the inter communication between robots is very important problem to be solved. These robots generally utilize wireless transmission system. The transmission sets send and receive on the same frequency or channel to establish the radio communication. This is called working simplex. The robots cannot start communication if both sets use different frequency channels. It is important to perform an initial configuration for establishing the radio signal transmission at a first contact among strange mobile robots. To solve this problem, this paper describes an information transmission system using an invisible code on displays which show an expression of robot's eyes.
icec2010_submission_84.pdf (344.99 Ko) Télécharger le fichier
hal-01055599 , version 1 (13-08-2014)
Paternité
Takeru Furukawa, Kunio Sakamoto. Eye Contact Communication System between Mobile Robots Using Invisible Code Display. 9th International Conference on Entertainment Computing (ICEC), Sep 2010, Seoul, South Korea. pp.468-471, ⟨10.1007/978-3-642-15399-0_62⟩. ⟨hal-01055599⟩
92 Consultations
126 Téléchargements
