Automatic Mobile Robot Control and Indication Method Using Augmented Reality Technology - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A mobile robot is an automatic machine that is capable of movement in a given environment. Many techniques of automatic control are proposed. A line tracer is one of the most popular robots. The line tracer goes along a white line on the floor. The authors developed a mobile robot which moves to indicated point automatically. All you have to do is to indicate a goal point. In this paper, we propose an automatic mobile robot system controlled by a marker and remote indication using the augmented reality technology.
icec2010_submission_83.pdf (355.52 Ko) Télécharger le fichier
hal-01055600 , version 1 (13-08-2014)
Paternité
Koji Ohmori, Kunio Sakamoto. Automatic Mobile Robot Control and Indication Method Using Augmented Reality Technology. 9th International Conference on Entertainment Computing (ICEC), Sep 2010, Seoul, South Korea. pp.464-467, ⟨10.1007/978-3-642-15399-0_61⟩. ⟨hal-01055600⟩
101 Consultations
109 Téléchargements
