Desktop Micro Forming System for Micro Pattern on the Metal Substrate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this Research, the desktop micro forming manufacturing system has been developed. A micro forming system has been achieved in Japan and its developed micro press is limited to single forming process. To coincide with the purpose to be more practical, research and development is necessary about the press which the multi forming process is possible. Micro patterned metal components are used in so many precision engineering fields. This micro pattern plays an important part in the functional movement of precision module. This micro pattern on the metal component can be made by EDM(Electro Discharge Machining). But this EDM method has low productivity because EDM tools can be worn easily. If another manufacturing process is developed with high productivity, industries can product the competitive goods. So we research on the forming process and system to make micro functional pattern on the metal component.
Paper_25_-_SONG.pdf (362.24 Ko) Télécharger le fichier
hal-01055671 , version 1 (13-08-2014)
Paternité
Hye-Jin Lee, Jung-Han Song, Sol-Kil Oh, Kyoung-Tae Kim, Nak-Kyu Lee, et al.. Desktop Micro Forming System for Micro Pattern on the Metal Substrate. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.301-308, ⟨10.1007/978-3-642-11598-1_35⟩. ⟨hal-01055671⟩
104 Consultations
258 Téléchargements
