Alignment Procedures for Micro-optics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The alignment procedure is an important step in the process chain of the assembly of micro-optical components and has a direct impact on the system performance of the micro-optical system, the necessary assembly time and the manufacturing costs. For these reasons, only alignment procedures that are adapted to the special requirements of each assembly task will be able to save costs and attain the best optical system performance. The paper describes the alignment methods and illustrates the assembly procedures based on selected micro-optical examples.
Paper_1_-_Mohaupt.pdf (296.6 Ko) Télécharger le fichier
hal-01055691 , version 1 (13-08-2014)
Paternité
Matthias Mohaupt, Erik Beckert, Ramona Eberhardt, Andreas Tünnermann. Alignment Procedures for Micro-optics. 5th IFIP WG 5.5 International Precision Assembly Seminar (IPAS), Feb 2010, Chamonix, France. pp.143-150, ⟨10.1007/978-3-642-11598-1_16⟩. ⟨hal-01055691⟩
293 Consultations
3843 Téléchargements
