Analysis of the Harmonizing Potential of Order Processing Attributes in Spread Production Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The paper discusses an approach how to measure the competitive advantage of harmonized order processing data by making use of knowledge about the interdependencies between related benefit dimensions. Corresponding harmonization projects are all projects that strive for common structures in product attributes, classification systems or product structures. The main objective of the underlying research work is the development of a method for the estimation of the benefit potential of harmonized order processing data.
03380337.pdf (501.42 Ko) Télécharger le fichier
hal-01055835 , version 1 (13-08-2014)
Paternité
Dirk Oedekoven, Volker Stich, Tobias Brosze, Stefan Cuber. Analysis of the Harmonizing Potential of Order Processing Attributes in Spread Production Systems. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.342-349, ⟨10.1007/978-3-642-16358-6_43⟩. ⟨hal-01055835⟩
135 Consultations
101 Téléchargements
