Legendre Transform and Applications to Finite and Infinite Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Set-Valued and Variational Analysis Année : 2016
We investigate convex constrained nonlinear optimization problems and optimal control with convex state constraints in the light of the so-called Legendre transform. We use this change of coordinate to propose a gradient-like algorithm for mathematical programs, which can be seen as a search method along geodesics. We also use the Legendre transform to study the value function of a state constrained Mayer problem and we show that it can be characterized as the unique viscosity solution of the Hamilton-Jacobi-Bellman equation.
squared.pdf (368.29 Ko) Télécharger le fichier
hal-01055917 , version 1 (14-08-2014)
hal-01055917 , version 2 (14-04-2016)
Cristopher Hermosilla. Legendre Transform and Applications to Finite and Infinite Optimization. Set-Valued and Variational Analysis, 2016, ⟨10.1007/s11228-016-0368-5⟩. ⟨hal-01055917v1⟩
400 Consultations
1178 Téléchargements
