Fault-Tolerant Power-Aware Topology Control for Ad-Hoc Wireless Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Minimizing energy consumption and ensuring fault tolerance are two important issues in ad-hoc wireless networks. In this paper, we describe a distributed topology control algorithm which minimizes the amount of power needed to maintain bi-connectivity. The algorithm selects optimum power level at each node based on local information only. The resultant topology has two properties: (1) it preserves the minimum energy path between any pair of nodes and (2) it ensures fault tolerance by maintaining bi-connectivity. By presenting experimental results, we show the effectiveness of our proposed algorithm.
Fault-Tolerant_Power-Aware_Topology_Control_for_Ad-Hoc_Wireless_Networks.pdf (452.05 Ko) Télécharger le fichier
hal-01056304 , version 1 (18-08-2014)
Paternité
Harichandan Roy, Shuvo Kumar De, Md. Maniruzzaman, Ashikur Rahman. Fault-Tolerant Power-Aware Topology Control for Ad-Hoc Wireless Networks. 9th International IFIP TC 6 Networking Conference (NETWORKING), May 2010, Chennai, India. pp.303-314, ⟨10.1007/978-3-642-12963-6_24⟩. ⟨hal-01056304⟩
83 Consultations
304 Téléchargements
