Efficient Recovery from False State in Distributed Routing Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Malicious and misconfigured nodes can inject incorrect state into a distributed system, which can then be propagated system-wide as a result of normal network operation. Such false state can degrade the performance of a distributed system or render it unusable. For example, in the case of network routing algorithms, false state corresponding to a node incorrectly declaring a cost of 0 to all destinations (maliciously or due to misconfiguration) can quickly spread through the network. This causes other nodes to (incorrectly) route via the misconfigured node, resulting in suboptimal routing and network congestion. We propose three algorithms for efficient recovery in such scenarios and prove the correctness of each of these algorithms. Through simulation, we evaluate our algorithms - in terms of message and time overhead - when applied to removing false state in distance vector routing. Our analysis shows that over topologies where link costs remain fixed and for the same topologies where link costs change, a recovery algorithm based on system-wide checkpoints and a rollback mechanism yields superior performance when using the poison reverse optimization.
main.pdf (510.79 Ko) Télécharger le fichier
Dates and versions
hal-01056312 , version 1 (18-08-2014)
Attribution
Identifiers
Cite
Daniel Gyllstrom, Sudarshan Vasudevan, Jim Kurose, Gerome Miklau. Efficient Recovery from False State in Distributed Routing Algorithms. 9th International IFIP TC 6 Networking Conference (NETWORKING), May 2010, Chennai, India. pp.198-212, ⟨10.1007/978-3-642-12963-6_16⟩. ⟨hal-01056312⟩
175 View
114 Download
Share
