Performance Impacts of Node Failures on a Chord-Based Hierarchical Peer-to-Peer Network - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2010
Peer-to-Peer networks are designed to provide decentralized, fault-tolerant alternatives to traditional client-server architectures. In previous work, the the resilience of structured P2P networks has been evaluated analytically as well as by simulation. In this paper, we discuss the influence of peer failures on a core component of our cost-optimized hierarchical P2P protocol Chordella. We show that the used algorithms lead to a working system even if a high number of superpeers is subject to failures.
013_EunicePerformanceImpacts_v2_28Final_Version_29_v1.pdf (407.03 Ko) Télécharger le fichier
Dates and versions
hal-01056490 , version 1 (20-08-2014)
Attribution
Identifiers
Cite
Quirin Hofstätter. Performance Impacts of Node Failures on a Chord-Based Hierarchical Peer-to-Peer Network. 16th EUNICE/IFIP WG 6.6 Workshop on Networked Services and Applications - Engineering, Control and Management (EUNICE), Jun 2010, Trondheim, Norway. pp.256-258, ⟨10.1007/978-3-642-13971-0_25⟩. ⟨hal-01056490⟩
77 View
56 Download
Share
