Scheduling malleable task trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Solving sparse linear systems can lead to processing tree workflows on a platform of processors. In this study, we use the model of malleable tasks motivated in [Prasanna96,Beaumont07] in order to study tree workflow schedules under two contradictory objectives: makespan minimization and memory minization. First, we give a simpler proof of the result of [Prasanna96] which allows to compute a makespan-optimal schedule for tree workflows. Then, we study a more realistic speed-up function and show that the previous schedules are not optimal in this context. Finally, we give complexity results concerning the objective of minimizing both makespan and memory.
RR-8587.pdf (663.71 Ko) Télécharger le fichier
hal-01059704 , version 1 (01-09-2014)
  • HAL Id : hal-01059704 , version 1
Loris Marchal, Frédéric Vivien, Bertrand Simon. Scheduling malleable task trees. [Research Report] RR-8587, INRIA. 2014. ⟨hal-01059704⟩
147 Consultations
127 Téléchargements
