Texture evolution in Nd:YAG-laser welds of AZ31 magnesium alloy hot rolled sheets and its influence on mechanical properties - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Materials Science and Engineering: A Année : 2011
AZ31 hot rolled magnesium alloy presents a strong basal texture. Using laser beam welding (LBW) as a joining process induces high temperature gradients leading to major texture changes. EBSD was used to study the texture evolution, and tensile tests coupled with speckle interferometry were performed to understand its influence on mechanical properties. The random texture obtained in the LBW fusion zone is mainly responsible for the yield strength reduction.
Matériaux
MSMP_Jmsea_Masse_2010.pdf (1.32 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01059768 , version 1 (01-09-2014)
Loreleï Commin, Myriam Dumont, René Rotinat, Fabrice Pierron, Jean-Eric Masse, et al.. Texture evolution in Nd:YAG-laser welds of AZ31 magnesium alloy hot rolled sheets and its influence on mechanical properties. Materials Science and Engineering: A, 2011, 528 (4-5), pp.2049-2055. ⟨10.1016/j.msea.2010.11.061⟩. ⟨hal-01059768⟩
89 Consultations
194 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
