Lean First, Then Automate: An Integrated Model for Process Improvement in Pure Service-Providing Companies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Born in manufacturing environment, only recently Lean Management has been implemented in service context. However, in literature we didn't find a strong empirical evidence to clarify how Lean Management can be applied in a pure-service context, such as banking/financial services, where there is an intensive use of automation and Information Technology Systems. This work aims to define a methodology to streamline and automate processes and reduce waste in the pure service-providing companies. To achieve the study aims we conducted three case studies. Based on the empirical investigation, a framework was developed. We found out that the automation of a process not streamlined can generate problems that can slow down the flow and increase errors. A process must be mapped to highlight waste. Only when the new process is streamlined it can be automated. In doing so the new process will automate only value-added activities recognized by the customers.
03380568.pdf (50.23 Ko) Télécharger le fichier
hal-01060463 , version 1 (04-09-2014)
Paternité
Thomas Bortolotti, Pietro Romano, Bernardo Nicoletti. Lean First, Then Automate: An Integrated Model for Process Improvement in Pure Service-Providing Companies. International Conference on Advances in Production and Management Systems (APMS), Sep 2009, Paris, France. pp.579-586, ⟨10.1007/978-3-642-16358-6_72⟩. ⟨hal-01060463⟩
169 Consultations
1351 Téléchargements
