Facial Expression Analysis and The PAD Space - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present a technique for facial expression analysis and representing the underlying emotions in the PAD (Pleasure-Arousal-Dominance) space. We develop a purely appearance based approach using Multi-scale Gaussian derivatives and Support Vector Machines. The system can generalize well and is shown to outperform the baseline method.
output.pdf (284.17 Ko) Télécharger le fichier
hal-01061096 , version 1 (05-09-2014)
  • HAL Id : hal-01061096 , version 1
Varun Jain, James L. Crowley, Augustin Lux. Facial Expression Analysis and The PAD Space. PRIA 2013 - 11th International Conference on Pattern Recognition and Image Analysis, Russian Academy of Sciences, Sep 2013, Samara, Russia. ⟨hal-01061096⟩
138 Consultations
464 Téléchargements
