The CO2 Pollution Map: Lessons Learned from Designing a Visualization that Bridges the Gap between Visual Communication and Information Visualization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jeremy Boy
  • Fonction : Auteur
  • PersonId : 959591
Jean-Daniel Fekete
We present the design of the CO2 Pollution map, a web-based visualization that uses motion design techniques to assist users in interpreting semantic information about the data. We describe our motivations and inspirations, found in the fields of graphic and motion design, and present how free visual variables can be used to create an impression of what the data are about. We finish by reporting an early evaluation of the impact of the visualization, which we published in the form of a data journalism article.
_C02_Pollution_Map_FINAL.pdf (856.46 Ko) Télécharger le fichier
hal-01061773 , version 1 (08-09-2014)
  • HAL Id : hal-01061773 , version 1
Jeremy Boy, Jean-Daniel Fekete. The CO2 Pollution Map: Lessons Learned from Designing a Visualization that Bridges the Gap between Visual Communication and Information Visualization. IEEE Conference on Information Visualization [Poster paper], Nov 2014, Paris, France. ⟨hal-01061773⟩
301 Consultations
419 Téléchargements
