Wireless networks appear Poissonian due to strong shadowing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Geographic locations of cellular base stations sometimes can be well fitted with spatial homogeneous Poisson point processes. In this paper we make a complementary observation: In the presence of the log-normal shadowing of sufficiently high variance, the statistics of the propagation loss of a single user with respect to different network stations are invariant with respect to their geographic positioning, whether regular or not, for a wide class of empirically homogeneous networks. Even in perfectly hexagonal case they appear as though they were realized in a Poisson network model, i.e., form an inhomogeneous Poisson point process on the positive half-line with a power-law density characterized by the path-loss exponent. At the same time, the conditional distances to the corresponding base stations become independent and log-normally distributed, which can be seen as a decoupling between the real and model geometry. The result applies also to Suzuki (Rayleigh-log-normal) propagation model. We use Kolmogorov-Smirnov test to empirically study the quality of the Poisson approximation and use it to build a linear-regression method for the statistical estimation of the value of the path-loss exponent.
PoissonShadowing06-onecolumn.pdf (369.07 Ko) Télécharger le fichier
hal-01064378 , version 1 (16-09-2014)
hal-01064378 , version 2 (10-02-2015)
Bartlomiej Blaszczyszyn, Mohamed Kadhem Karray, Holger Paul Keeler. Wireless networks appear Poissonian due to strong shadowing. 2014. ⟨hal-01064378v1⟩
248 Consultations
324 Téléchargements
