Learning a Repertoire of Actions with Deep Neural Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We address the problem of endowing a robot with the capability to learn a repertoire of actions using as little prior knowledge as possible. Taking a handwriting task as an example, we apply the deep learning paradigm to build a network which uses a high-level representation of digits to generate sequences of commands, directly fed to a low-level control loop. Discrete variables are used to discriminate different digits, while continuous variables parametrize each digit. We show that the proposed network is able to generalize learned actions to new contexts. The network is tested on trajectories recorded on the iCub humanoid robot.
camera_ready.pdf (1013.34 Ko) Télécharger le fichier
hal-01065741 , version 1 (18-09-2014)
  • HAL Id : hal-01065741 , version 1
Alain Droniou, Serena Ivaldi, Olivier Sigaud. Learning a Repertoire of Actions with Deep Neural Networks. Joint International Conference on Development and Learning and on Epigenetic Robotics (ICDL-EpiRob), Oct 2014, Italy. 6 p. ⟨hal-01065741⟩
292 Consultations
790 Téléchargements
