Control of Dual-Airfoil Airborne Wind Energy systems based on nonlinear MPC and MHE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Airborne Wind Energy (AWE) systems generate energy by flying a tethered airfoil across the wind flow at a high velocity. Tethered flight is a fast, strongly nonlinear, unstable and constrained process, motivating control approaches based on fast Nonlinear Model Predictive Control (NMPC) and state estimation approaches based on Moving Horizon Estimation (MHE). Dual-Airfoil AWE systems, i.e. systems with two airfoils attached to a Y-shaped tether have been shown to be more effective than systems based on a single airfoil. This paper proposes a control scheme for a dual-airfoil AWE system based on NMPC and MHE and studies its performance in a realistic scenario based on state-of-the-art turbulence models.
Zanon2014a.pdf (1.62 Mo) Télécharger le fichier
hal-01068909 , version 1 (26-09-2014)
Mario Zanon, Greg Horn, Sebastien Gros, Moritz Diehl. Control of Dual-Airfoil Airborne Wind Energy systems based on nonlinear MPC and MHE. European Control Conference (ECC), 2014, Strasbourg, France. pp.1801 - 1806, ⟨10.1109/ECC.2014.6862238⟩. ⟨hal-01068909⟩
166 Consultations
401 Téléchargements
