A formally-verified C static analyzer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper reports on the design and soundness proof, using the Coq proof assistant, of Verasco, a static analyzer based on abstract interpretation for most of the ISO C 1999 language (excluding re-cursion and dynamic allocation). Verasco establishes the absence of run-time errors in the analyzed programs. It enjoys a modular architecture that supports the extensible combination of multiple abstract domains, both relational and non-relational. Verasco integrates with the CompCert formally-verified C compiler so that not only the soundness of the analysis results is guaranteed with math-ematical certitude, but also the fact that these guarantees carry over to the compiled code.
verasco-popl2015.pdf (334.38 Ko) Télécharger le fichier
hal-01078386 , version 1 (28-10-2014)
Jacques-Henri Jourdan, Vincent Laporte, Sandrine Blazy, Xavier Leroy, David Pichardie. A formally-verified C static analyzer. POPL 2015: 42nd ACM SIGPLAN-SIGACT Symposium on Principles of Programming Languages, Jan 2015, Mumbai, India. pp.247-259, ⟨10.1145/2676726.2676966⟩. ⟨hal-01078386⟩
657 Consultations
690 Téléchargements
