Time Asymptotics for a Critical Case in Fragmentation and Growth-Fragmentation Equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Kinetic and Related Models Année : 2016
Fragmentation and growth-fragmentation equations is a family of problems with varied and wide applications. This paper is devoted to description of the long time time asymptotics of two critical cases of these equations, when the division rate is constant and the growth rate is linear or zero. The study of these cases may be reduced to the study of the following fragmentation equation: $$\frac{\partial}{\partial t} u(t,x) + u(t,x)=\int\limits_x^\infty k_0(\frac{x}{y}) u(t,y) dy.$$ Using the Mellin transform of the equation, we determine the long time behavior of the solutions. Our results show in particular the strong dependence of this asymptotic behavior with respect to the initial data.
MiMa_KRM_TemplateMa3.pdf (1.08 Mo) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01080361 , version 1 (09-12-2014)
hal-01080361 , version 2 (19-01-2015)
hal-01080361 , version 3 (13-10-2015)
Marie Doumic, Miguel Escobedo. Time Asymptotics for a Critical Case in Fragmentation and Growth-Fragmentation Equations. Kinetic and Related Models , 2016, 9 (2), pp.47. ⟨10.3934/krm.2016.9.251⟩. ⟨hal-01080361v3⟩
592 Consultations
476 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
