A comparative study of fatigue behaviour of flax/epoxy and glass/epoxy composites - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Composites Science and Technology Année : 2012
Experimental investigations on flax and glass fabrics reinforced epoxy specimens, i.e. FFRE and GFRE, submitted to fatigue tests are presented in this paper. Samples having [0/90]3S and [±45]3S stacking sequences, with similar fibre volume fractions have been tested under tension–tension fatigue loading. The specific stress-number of cycles to failure (S–N) curves, show that for the [0/90]3S specimens, FFRE have lower fatigue endurance than GFRE, but the [±45]3S FFRE specimens offer better specific fatigue endurance than similar GFRE, in the studied life range (<2 × 10^6). Overall, the three-stage stiffness degradation is observed in all cases except for [0/90]3S FFRE specimens, which present a stiffening phenomenon of around 2–3% which could be related to the straightening of the microfibrils.
LAMPA_CST_GUILLAUMAT_2012.pdf (1.97 Mo) Télécharger le fichier
Format : typeAnnex_author
hal-01089436 , version 1 (01-12-2014)
Shaoxiong Liang, Papa-Birame Gning, Laurent Guillaumat. A comparative study of fatigue behaviour of flax/epoxy and glass/epoxy composites. Composites Science and Technology, 2012, 72 (5), pp.535-543. ⟨10.1016/j.compscitech.2012.01.011⟩. ⟨hal-01089436⟩
151 Consultations
601 Téléchargements
