Air blast reflecting on a rigid cylinder: simulation and reduced scale experiments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Shock Waves Année : 2015
In this paper, the Multi-Material ALE formulation is applied to simulate the propagation of an air blast through the atmosphere, and its reflection on an assumed rigid cylindrical obstacle. The mathematical and numerical implementations of this formulation are presented. In order to validate the formulation and prove its ability to capture the propagation and reflection of high pressure waves, comparisons of the simulations with the experimental blast pressure measured on an assumed rigid cylinder are performed. The simulation conducted via the presented models and methods gives good predictions for pressure time histories recorded on the rigid cylinder.
Fichier non déposé
hal-01099733 , version 1 (05-01-2015)
Alain Langlet, Mhamed Souli, Nicolas Aquelet, Girault G.. Air blast reflecting on a rigid cylinder: simulation and reduced scale experiments. Shock Waves, 2015, 25 (1), pp.47-61. ⟨10.1007/s00193-014-0531-6⟩. ⟨hal-01099733⟩
81 Consultations
0 Téléchargements
