Geometrical optimization of an ultrasonic tactile plate for surface texture rendering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Sensors and Actuators A: Physical Année : 2010
The Tactile plate consists of piezo-ceramics glued on a copper-beryllium resonator. Its purpose is to create pro-grammable tactile sensations, which give the illusion of finely textured surfaces. The illusion originates from the variable friction between a finger and the vibrating resonator, caused by the squeeze film effect. In order to obtain a maximal deflection of the plate for a minimal supply voltage, an optimization is carried out of the length, thickness, and width of both the resonator and the ceramics. Constraints are realistic geometrical dimensions, a resonance frequency of at least 25 kHz, and a low supply voltage. The plate is modelled by both an analytical and a numerical model. The maximal dynamical deflection per volt was achieved with thin piezo ceramics (0.5 mm) at the minimal frequency of 25 kHz. A high deflection can be obtained in a wide range of the resonator length. With increasing length, the optimal resonator thickness increases too. The plate width seems to have little influence. Experiments are carried out on two plates with different geometry.
2008_SensAct_TactileCell.pdf (702.04 Ko) Télécharger le fichier
hal-01110766 , version 1 (28-01-2015)
Peter Sergeant, Frédéric Giraud, Betty Lemaire-Semail. Geometrical optimization of an ultrasonic tactile plate for surface texture rendering. Sensors and Actuators A: Physical , 2010, pp.91-100. ⟨10.1016/j.sna.2010.05.001⟩. ⟨hal-01110766⟩
204 Consultations
189 Téléchargements
