Formal language for GeoSpelling - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computing and Information Science in Engineering Année : 2014
In order to tackle the ambiguities of Geometrical Product Specification (GPS), GeoSpelling language has been developed to express the semantics of specifications. A detailed syntax of GeoSpelling is proposed in this paper. A specification is defined as a sequence of operations on the skin model. The syntax is based on instructions used in computer programming language: call to functions and flow control by condition and loop. In GeoSpelling, the call to functions corresponds to the declaration of operations; loops make it possible to manage a set of features with rigor and conditions to select features from a set.
LCFC_JCISE_2015_BALLU.pdf (1.17 Mo) Télécharger le fichier
hal-01116055 , version 1 (13-02-2015)
  • HAL Id : hal-01116055 , version 1
  • DOI : 10.1115/1.4029216
  • ENSAM : http://hdl.handle.net/10985/9314
Alex Ballu, Luc Mathieu, Jean-Yves Dantan. Formal language for GeoSpelling. Journal of Computing and Information Science in Engineering, 2014, 35p. ⟨10.1115/1.4029216⟩. ⟨hal-01116055⟩
160 Consultations
313 Téléchargements
